Is there a way to add drop shadows to a library? From what I can tell this is not possible at the time. Coming from Figma where that can be set as part of your design system/library.
Where am I?
Shadows can't be added to the libraries, but I usually workaround this by adding to the library
Rectangles
with shadows β then you can easily Copy style + Paste style (it does override radius and colors, but if you Copy style from aRectangle
and then paste it into aBox
, it won't touch the font or the padding :)).
