Hi all,
I'm using UXPin coming from design tools Sketch and Figma in the past - I'm finding very little documentation on setting up constraints for new components. The controls are not following the same precedence that I'm used to. Is there more documentation on constraints? sample files?
Thanks!
d
Constraints in UXPin
Where am I?
Hi Dan,
Our documentation and all tips on using constraints can be found here.
For components to set an intended behavior when you resize them, it's best to set constraints in the Edit Master mode or just before turning an element into a component.
Unfortunately, I don't have any sample files for you, but I hope our docs shed some light on how to use constraints in UXPin!
Hi Natalia, appreciate the response and thank you for the tip.
