I'm trying to get content populated from a Google Sheet, as shown in the documentation. It's kind of working, but I'm having trouble getting the rows of data to populate in the right order. It seems to populate items in a completely random order, and when I refresh the data, it changes the order randomly. Is there a way to force the order to be consistent with the Google Sheet?
Where am I?
Hi Matt! CSV Data fill option is a very sensitive feature in terms of rendering data in the intended order. You’d need to make sure that the text elements in the layer panel are properly placed. The data should match the layers with the column names in the file you want to upload. If you want to have it in specific order you will need to change it in the file and after that fill data in prototype with the new CSV.
Hope this helps!
This is what I'm doing, but the data is always imported in random order. I found a post from 2 years ago from someone with the same issue, so it appears that UXPin isn't working on improving features. I'm growing increasingly frustrated that you aren't keeping up with other prototyping products.
