Post
Ask a Question Using a condition, is there a way to check if an element is currently visible?
Where am I?
Yes, if the elements visibility is set via states (eg base - visible, 2nd state - hidden)
You can use a condition to verify the active state and determine the following actions based on it.
Haha. I never even considered that. Thank you.
I prefer to set variables as you can have a single source to update them.
In this example, I set a visible is true to blueCircle. On hover on the yellowRectangle, it will check if is true and move the element.
