I'd like to have the ability to quickly remove all Interactions on objects in UXPin.
In working with other people's files, there are complex interactions set up on lots of elements - I'm reusing the objects but want all the interactions to go away since most of the time they break/have errors anyway after I copy the pieces to a new file.
Right now, I have to click on to every little object and manually X out of every set interaction. A way to Remove All Interactions on selected objects would save me a lot of time. Even better would be a way to sort Layers to see only those with Interactions, then strip away all interactions from there.
Thank you!
Hi Leiah,
It would be an interesting feature to have, indeed. Noted down!
Not a workaround, but I realized later that you can hide Interaction Indicators while working - so at least you can work on a file without the old interaction remnants distracting you.
View > Interaction Indicators > [uncheck]
